BOSCH QUIETCAST PREMIUM BRAKE PADS, 2-WHEEL SETReplace worn-down OE brake pads with Bosch QuietCast Premium Brake Pads. These have the same material type as your original pads, but boast of advanced platform-specific formulation to ensure top braking performance. They are also sculpted to match the chamfers and slots of the OE design, if any. Additionally, these feature rubber-core shims that are heat and pressure cured between two layers of steel to ensure excellent rubber-to-metal bonding that results in noise reduction, increased strength, and corrosion resistance. With Bosch QuietCast, you are assured of reliable braking performance that is pleasantly noise-free.Features:Integrally molded Unimold designLaminated OE-style rubber-core shimsSame-as-OE brake pad material typeAdvanced platform-specific pad material formulationPowdercoated backing plateSynthetic lubricant included. Auto Parts Warehouse has extensive Bosch Brake Pad Set catalogs.We are now offering FREE shipping on all Bosch Brake Pad Set orders over $50.00. Our secure bosch brake pad set catalog is available every hour of everyday. Shop with confidence for all your bosch brake pad set needs. Bosch Brake Pad Set are In Stock and available today. Save up to 60% off dealer price on your next Bosch Brake Pad Set purchase. Our online catalog contains a wide selection of the OEM and aftermarket parts you need at unbeatable prices
Store | Price |
AutoPartsWarehouse | [show price] |
Bosch 1983 Honda Civic Brake Pad Set Bosch Honda Brake Pad Set BP247 83 is just amazing! It is much worth than what you pay at AutoPartsWarehouse.
